Help not starting
Car  Clio MK1
I have recetly finished putting my 1.8 16v in to my RT. When i turn the key to put the ignition oni dont get any power to the car. Normally the centrol locking button works with out the ignition on. but in the case nuthin works Is there some wiring that need to be modifed to make it work?
Did it work in the doner car.
Check the fues can you hear the fuel pump startin up?
Stupid question but you did connect the barrery etc up correctly?
i connected the battery rite and i did hear the fuel pump going, Yes it did work in the doner car lol
Could be the engine loom. There are slightly different in the newer 16v/Williams, I had a problem when i converted mine to a williams lump! don't know if this might help? I used the original loom for the 16v engine.
