Nez Car White Megane R26 F1 230 Nov 28, 2006 #1 Sorry for poor quality pic, I've got a high res one if anyone wants it. A mate has been having problems when booting up, it just gets stuck on this page until they hit F1. After that its seems to work ok. Can anyone shed any light/help? Cheers
Griff Car 172 Cup Nov 28, 2006 #7 The 80 conductor cable warning simply means you're using an REALLY old ide cable which should ideally be changed.
manicmonkey Car Clio 172 ph2 + 990SM Nov 28, 2006 #8 he needs to use a different class. its looks pretty much the same, but has more wires in it
manicmonkey Car Clio 172 ph2 + 990SM Nov 28, 2006 #9 or change the settings in the bios to make it go slower
Nez Car White Megane R26 F1 230 Nov 28, 2006 #11 This all started the other night after a storm kill the power.. No new hardware installed. Does the cable need replacing?
manicmonkey Car Clio 172 ph2 + 990SM Nov 28, 2006 #12 maybe, but its a bit weird if you havent touched it. try goin into the bios and checking the settings - press delete try just goin in and saving the current setings
Nez Car White Megane R26 F1 230 Nov 28, 2006 #13 the_wanderer said: maybe, but its a bit weird if you havent touched it. try goin into the bios and checking the settings - press delete try just goin in and saving the current setings Click to expand... That seems to have sorted it. Thanks mate
