HELP please i have puddles
Car  clio 172 sport
Hi all i have a big puddle under my pass seat and a dam patch under my drivers seat i cant quite figure it out and was wondering if anyone else had or has this problem it sounds as though i have a sloshing noise from bulkhead area aswell if that may have something to do with it please help its starting to really annoy me
Thanks guys :)
What Mick said, IIRC they run in the bulkhead. The ones you probably need are located in the wheel arch. In the same part on both sides. Take arch liner off, and it's on the same side as the door, practically on the corner of the side skirt just above it. There is also one above the wheel, can't give exacts for that one though.
Clean out with a bit of wire, high pressure hose could help?
