Help!problems with my Clio :( Foglight when breaking+ Clicking from fusebox and other
  03 Clio 16V 1.2L
Hello,
I've got a few problems with my Clio that I need sorting.
When I break my fog light on my dashboard comes on, sometimes fully and sometimes flickers. It happens generally when I break hard. I've checked the fuses already and they are all fine.
Also when using the windows or windscreen wipers, theres a clicking noise coming from the glove box, more likely the fuse box, it gets quite annoying when using the wipers. and now there is a thumping noise from my sub when i do it, and it is quite loud. When I turn the wheel my revs drop slightly and all the lights dimm and it looks like there is no power.
and recently my sub has started thumping randomly and when i operate the windows just like the clicking noise but my sub does it as well. It does it if my music is on a low volume and if i turn it up it goes.
i Have tried searching about my sub but cannot find ANYTHING, I think it could be a lack of power to the sub.
Any help or other links will be much appreciated. thankss ;)
Re: Help!problems with my Clio :( Foglight when breaking+ Clicking from fusebox and o
The clicking is the fuse activiating, should by in syncro with the wipers if they are on intermittent or when using the rear wiper.
The brake light is generally dirt in the rear cluster on the dirvers side, take it apart and give the connections a clean out.
  Ph2 Clio 172
Fog light is an issue I had. Took the drivers side rear cluster off, cleaned all the connectors, plugged it back together and it worked fine.... for about a month. Just ignore it now and put it down to dodgy French electrics.
