< HELP > Removing Door cards Mk2
Right, i need to remove the external door handles... which means removing the whole door card from my 172.
how do i do it?
I've unscrewed all the screws i can see (including the one on the handle) etc.. and pulled the putty away around the bottom but the top of the panel wont budge!
how do i get it off?
Many thanks :star:
  Mercedes SLK350
Once you have taken out the screws at the bottom, and the one in the handle, it is only the black mastic holding the panel.
If you have freed the mastic at the bottom, then you need to lift the panel upwards, it will come away as far as the internal wires will allow.
  A well built VW
The mastic is a b*****d sometimes just give it a good tug and lift upwards it should come off fine , think its just two bolts and a rod to remove the handles iirc
ah, thats what im doing wrong... im not lifting upwards!
does it help with the window up/down?
  1.6 Focus, 1.6 122S
am trying to remove my handles aswell, is there an answer to this?
