help! sidelights don't work
Car  Clio 172
hello, i've posted this before, but had no reply. worth a try again... sidelights on my 172 don't work. dash illuminates when i turn the sidelights on, but nothing outside. xenons, full beams and fogs work fine though.
the driver side went first, then came back on for a while, and then both failed and nothing since.
rentech had a look when i had it serviced and said it's not the bulbs. read a few posts which suggest it might be fuses or relays.
can anybody help please?
thanks!
sorry, yeah tried the fuses. unplugged and plugged back in the relays too. but nothing... what to do?
If its not bulbs, get a test light/multimeter and see if your getting 12v to the little block plug for the side lights first, go from there.
sounds like the bulbs are the wrong way around as they are L.E.Ds?
they only work one way round.
also check do rear lights come on ?(side lights?)
make sure the bulbs arent blown up
make sure they are in the right way as there is a + and -
make sure the fuse isnt blown up and is the correct size
Have you checked earthing cables? Might be loose or you might have a broken wire somewhere.
Faulty relay switch?
Dirty or corroded bulb/bulb holder contacts?
Faulty switch?
thanks for the posts! just a quick question - can anybody tell me where the sidelights are grounded to please? thanks again!
