HELP!! Spring fit problem
  V6 engined Mk3 Astravan
righto, bought some 55mm lowering springs to replace my 35mm ones, did the drivers side no problem, went to the other side, and i cant seem to get the 'top cap' bit off from under the bonnet, its totally seized solid, (the one with the 6mm allen key bolt in the centre then the 21mm nut) can anyone give me any advice on how i might be able to ease it? tried spraying gt85 on it with no luck, :dapprove: need the car asap too, real problem, any ideas anyone?
thanks,
Jonny
