Help! VPN is dead slow and stop
  Astra CDTI SRI
Something on my network is hogging the VPN bandwidth between head office (me) and the other 3 offices.
Any suggestions on what software I can use to find out what it is?
  Fiesta ST2
disable the VPN and see who complains! also if you have alot of servers it could be replicating AD/DNS/DHCP or even files.
  Glacier White 200
Assume this is an IPSec VPN? If so all three tunnels will terminate on your network right?
Have you checked your VPN Concentrator/Firewall to make sure its interfaces are not dropping packets or misconfigured with speed/duplex. Check the cpu load/memory on the VPN Concentrator/Firewall.
Also check the bandwidth load inbound and outbound on your internet interface at the head office.
If the problem is affecting all remote sites then it's likely to be some sort of loading/performance issue on the main hub site.
The above assumes the topology is the remote sites are spokes and you are the hub with all routing between sites going via yourself.
