Help warranty
Car  Titanium 182
My car is booked in for a few things under warranty tomorrow
1. One thing is the air con didnt have any gases in it, so they refiled it with a dye, which shows up under Ultra violet let, no i check this and there is yelloow dye in most places so to me they should fix it
2. The door car is squeaking like hell
3. The rear wheel bearing is whinning on, but the car is lowered on HR's
4. I think there is a oil leak
To me they should all be fixed except the wheel bearing which i think they will be dodgy about
ANy ideas?
Put your standard shock and springs back on, then they should replace it, wheel bearing is not a cheap fix.
So your saying Renault regassed the air con and it's still not working ? It should be a warranty job then . Get them to check it again .
Whats a door car ??
Like DrRollo says . Back to standard for your suspension or they will most likely blame you dropping it on H+R's
You " think " there is an oil leak ? Be a bit more specific . Can you actually see any oil leaking ? Its accepted by Renault that they " can " use up to 1 litre per 1000 miles . Maybe yours just burns a bit more oil than others .
sorry i mean door card
Unsure about the leak but when you give it some it smells like its dropping onto the manifold and burning as there is a strong smell of it, cant seem to see it anywhere
With regards to the air con, it was empty and they refilled it and its still not working properley
I doubt they'll do anything about the door card . All the cars rattle and squeak abit , lol .
Have you got a plastic engine cover on ? If you have take it off and check on the top of the engine , towards the left hand side . They can leak from one of the bolts . If you do a search you might find some more info about it . It's been mentioned a couple of times before .
Get them to check the aircon again for leaks .
Its a cup doesnt have a cover looked all over the engine etc
only bit i aint looked is from underneath under the below engine cover
We will have to see tomorrow
hummm...>If they can avoid doing the work under warrenty then they will.
These will be the excuses...
Oil leak - due to excessive speeds & Increased temp....
Rattling door card - Due to Blueflame zorst...(Actuallt i could almost beleive that! ;))
Bearing - Defo due to coilovers.
Air con - Due to justin bein a stinky b*****d! - Although there not to know that
lol
Air con should be fixed.
FDoor just needs greese most likly.
Wheel bearing is covered.
Thinking there an ol leak or proof that oil leak is serious enought o warent action is a different thing.
