Help will these fit
I think they will be 100 PCD as that's what some VW and Vauxhalls are. You need to ask the seller to be sure. Need to be 4 x 100 PCD and centre bore 60.1
This is what the seller said Hi PCD is 100, centre bore is 71 at the rear and 58 at the front, ?
Guessing they mean internal and external parts of the wheel. Could need a rebore unless they're spigot rings that are the reducing factor. Could be more hassle than it's worth. Are they local for you to look at/trial fit?
