Help with Mk1 Relay.
Car  Renault clio mk1 p3
Please take a look as the picture via this link: http://www.putfile.com/pic.php?img=4474063
Now i have a set of valver clocks in my car and would like to get the temp display working.
I know about the outside sensor.
I see on the diagram there is a relay for "External Temperature Display" (9).
Do i need this to get it to work?
If so would any one have one for sale?
Thanks for reading.:cool:
The thermostat is in the passenger wing mirror and only came on the 16v and williams. Your gonna need a mirror and the wiring that plugs into the back of the clocks.
Amir
I am fairly sure that that "relay" is just the chime that indicates the road temp has dropped to 3deg. Your temp gauge should work without it.
I wouldn’t go swapping relays to test though, relays may look the same but they are not necessarily wired up the same, you could burn out a loom.
