Mazda Rx8
I've done lots of searching but to no avail. Ever since buying the car there has been what I assume is an exhaust noise.
I have standard cat and K-tec 2.25 inch catback
From 2.75k rpm up there is a whistle almost rasp (not the good kind) more prominent with harder throttle.
Then in the upper revs it turns into an almost tinkling sound.
So far I've replaced all gaskets and bolts ( cat to manifold sprung joint with genuine Renault kit, olive joint has new beefy clamp on and high temperature sealant, two rear sleeve joints have new clamps)
I've also replaced all the exhaust mounts and checked all the heatsheilding (washered a few loose ones) but still the noise persists!!
It doesn't do it in neutral when I try and replicate it on the drive also.
Anyone have any clue?!?!?
Sent from my SM-G950F using Tapatalk
