help with wheel spacers
Car  Clio 2.0 16v 172 Sport
Looking at putting some wheel spaces on my 2001 172. Car is lowered 35mm. Ive had a look on here and most people are opting for 10-15mm Hubcentric spacers.
Question is - should i be putting same spacers front and rear? Any photos would be appreciated so i can see how they look on the car. I understand Verom Motorsport are good place to get these from?
venom are pretty competative with prices, they are only a few quid dearer than ordering direct from the factories..
you can fit 15mm all round but personally the optimum set up for standard wheels is 15mm front an 5mm rear with standard tracking/camber settings....
in that point of view why you don't put just on drivers side? lol
you should put the same size at 4 wheels!!!
why??
it's fwd so having a wider front track helps you put power on earlyer going through/coming out of corners and the front arches are wider than the rears which helps with the look of the car!!
just my opinion though, if somthing else works for your driving style then im not saying your wrong...
