Help with which speakers?
Car  Clio Dynamique
Hi, i have a Renault clio mk2 ph1 MTV. All i have at the moment is the original MTV CD player which is not the best, and the standard speakers.
I will be getting this JVC head unit, mainly because of the USB port.
http://www.halfords.com/webapp/wcs/..._productId_509309_langId_-1_categoryId_165474
I want to change the speakers, only in the front as i dont really use the back ones. Im not after anything perfect/expensive, just something reasonably priced with good sound. Anything is better than my standard set up that i currently have!
I had a look on Halfords, and found these:
http://www.halfords.com/webapp/wcs/..._productId_237965_langId_-1_categoryId_165707
http://www.halfords.com/webapp/wcs/..._productId_504845_langId_-1_categoryId_165707
Without sounding too dumb, i have very little knowledge on how to fit them. I think these will fit directly, not sure about the wiring though?
I need a pair that will fit directly and are easy to wire for under 100 quid, and obv that sound good.
Any help would be appreciated! Otherwise it might be a case of Halfords fitting them for me :o
Sorry,are you trying to buy a headunit,door speakers and get them all fitted for under £100?
I know it depends on your budget and individual circumstances but I wouldnt even be looking at a headunit for under £100 but as for the speakers I would go for the second ones mate,the pioneers. Seems to be the better speaker out of the 2 but you really cant tell by looking at them on the internet,you need to hear them
Hi, sorry i am just after speakers for the front doors. I will be getting that head unit, but im after advice on which speakers are the best for under 100 quid. I want to fit them myself hopefully, so if i could find a direct replacement that would be perfect. If not then i will pay Halfords to fit em. Thanks
Am i right in thinking that i need the speakers to be 13cm across and 5.25" depth? Also will they just plug'n'play or will i need to re-wire them? Thanks, james
