help
Car  172 vr6 golf
hi there. rite i done a such and done the self check on the dash with the holding of the wiper stalk and i have d-t come up. i done another such and found that this is an injector fault a mate of mine pluged it on to the snap on scan tec and found all of nothing.
i also cant find where the injectors are. any help would be good thanks people.
its a 172 with a phase 2 chip, would this be the problem?
The faults there arn't that important I'd just clear then and forget it the faults can be internals Rneualt ones and snap on won't pick up
Injectors are under the injectors cover do a search for pictures but its the big metal bit down the front of the engine between the engine and radiator. or ask your mate to show you 2 x 10mm bolts hold it on stick them on extensioners down the hold in the injectors metal cover thingie.
What do you mean 172 with phase 2 chip?
