help!
Car  Clio 1.5 GT
I changed the ecu on my 1.2 16v clio, which cured the permanent limp mode, but left the emissions light on, car was running fine for months but then randomly went into limp mode when pulling onto a roundabout (some poo came out) so I pulled over and turned the car off and back on which cured it and was fine for the rest of the way home, ran fine then until 2 days after, now it constantly goes into limp mode! would start up and if I revved it hard it would limp! when I hold the revs, *2000* it drop and raise between 1950 and 2050, I thought missfire so I changed the spark plugs, went straight into limp and cut out, then after a few starts it was fine but the revs are still hunting. and ideas what this might be? ive code read it and its come up as pedal track 1malfunction , and pedal track 2 short curcuit, which were the codes on the last ecu also and will not clear! any help would be much aappreciated
why change the ecu? that won't be the problem!!!
throttle pedal or throttle body and occasionally fuel pump and the main 3
