Help
Sash
  A Yellow One
If the head unit has a hardwired aux in port then yes, feed it through the centre console and drill a hole in the ashtray or something?
  Clio 182
If it has an aux it will be in back, tbf you can pick up a brand new stereo for under £50 with aux
  Polo + Micra
i would of thought you would have an aux input but probably includes a video input with it
  mk1 Octavia VRS
You can get SD cards and USB flash drives dirt cheap. I much prefer those options to an aux input because you don't rely on the battery of whatever you're using to output to the head unit.
  Clio 182
If it's a screen I'd presume if there was an aux in rear then there would be an icon on screen (if touchscreen) that would be grayed out, or a source would show aux also, what's make/model of stereo?
  Clio 182
If there's an aux source and no iput on facia then more than likely be rear input, some are RCA-Aux, and some are 3.5mm, no way of telling till you pull it out
