hesitant throttle response and misfire
Matt e
Been having quite annoying problem lately, on start up the car has a rough idle i know people say this is normal for 172/182 buts it was fine up to a couple of months ago. also when i pull away the cars throttle response it quite hesitant and has a misfire.
it drives fine, but when i slow down for other cars or to turn in it seems to misfire again,
so far the things i have done are
new injectors
new lambda
cleaned tdc
throttle body
map sensor
today i checked to see what condition the spark plug were in, they look ok, after i put the spark plugs back in i was listing to the engine and i could hear like arcing/spark sound coming from either the ht leads or coilpack, could this be causing the problems?
Last plug looks knackered, but it might be a bad picture.
Arching is bad and would definitely cause issues
i thought id update this, i changed the spark plug, ht leads and coilpack last week and now it seems to be fine
so must have been one of them
