Hesitant Valver - Urgent help needed
  Clio Mk1 Hybrid
This morning I drove my 93 Clio 16v to work as normal, 40 minute journey, fairly heavy traffic. On a few occasions the car felt as if was going to cut out, like the car was running out of petrol, it was a bit hesitant.:( The engine speed was around 4.5-5k.
What could this be?:confused:
Is it the start of fuel pressure regulator problems or am I looking at something electrical?
Or could it just be bad fuel?
Any suggestions would be most welcome.
James
  Clio Mk1 Hybrid
It was doing it throughout the trip.
I have just had a look under the bonnet and the engine sounds as if it is hunting/misfiring, not a lot just slightly.
I am wondering if I have a fouled spark plug or if the dizzy cap is tracking.
James
Doesnt sounds like any of the commen valver engine faults to be honest so hopefully itll be something simple like a knackered lead or what you have said.
Exhaust Gas Pressure sensor, or something similar (Common / Known fault on newer clios), gives symptoms similar to those youre describing, - happened with my old 1.2 Y reg. Just a thought.
