Hey guys! Does anyone know this Clio!
lol At even considering a car someone can't be arsed to clean for pictures, and then takes them on a builders yard!
welcome to cs
totally agree with that ^^^
also says it has rain sensative headlights???? tbh he should know all that sort of stuff if he has built it :S
imo avoid it and get a cheap C1 or yaris ect like fletcher said
not two menton poor speeling and gammer. :rasp:;)
Airbag light is either due to ill fitting connectors under the seat (5 minute job-Remove connectors and solder the wires instead) or its had a smack and the airbags have gone off. If its the latter, it needs a new computer and they are mega bucks from Renault.
ABS light could be anything. Its an MOT failure though, so bear that in mind.
But to answer your last question, if the light is on, it won't work. ABS or Airbags. So good luck if you have to brake suddenly in the wet before you go up the back of a transit! lol!!
