HID Fitting Help
Car  Renault Clio 1.2 16V
i got some hid lights and i have no instraction and i went to fit them today but i did not know how to make the bulbs clip in and stay there.
any help would be great :)
thanks
If it is an H7 kit they can be a pain without the correct clips, as you can buy specific ones for H7 fitments. You can alter normal H7 clips to fit them though. I'll try and dig out a picture of the sort of clip you need so that you can suss out how to alter the standard one!
This is what you are after:
you can cut the original ones, just so you can thread the wires though.
I have the clips available for £5 posted if you need any.
If you split the rubber bung, the one that holds the wires together on the kit, you can feed each wire through seperately, meaning no cutting is needed.
