Ideally needs to be completely standalone. I can rig and old PC up for the recording.you could get away with a decent IP camera and record on any laptop/computer.
it depends if you want a dedicated recorder or not?
I use an old desktop that isn't connected to the web, so just records 24/7 365 days a year.
I am all about the crowd too.In home camera?
I got my ipcamera off ebay, cracking bit of kit. it has never left me down, just sits there day after day recording onto a 1tb hard drive.Ideally needs to be completely standalone. I can rig and old PC up for the recording.
Doesn't @Gaz_ do home security setups? Might be home entertainment - but someone definitely deals with this stuff on here...
I did, but I couldn't remember if it was you or not, I knew Gaz also did it so edited you out, in case I was wrong and dragged you into a random threadIt says you've tagged me?! Which would be correct!
How much for all that, excluding the ipad (this needs a wall mounted screen of decent size?Hi!
3x 2CD-2732 HIKVision domes with built in Micro SD cards and an iPad mini with app and done.
How do they draw power?
Do you work nationally?Draw power using Power over Ethernet. So you just have one Ethernet cable going to it and it draws it from a POE network switch.
For all that your looking at about £800+VAT.
If you wanted a monitor you would need to connect it all to an NVR so looking at another £500+VAT.
These are proper quality though.
Standard CCTV Image
Vs. HIK Vision at 1080p 30FPS
I'd have two commercial locations for you to do. One needing 2 cams and one needing 3 cams.
Can supply info for quote if needed.
Something like this
http://www.cctvsuppliersuk.co.uk/se...xel-ip-cctv-kit-4-channel-nvr-with-4-cameras/
Plus a monitor. Then think about hooking it into your network for remote viewing via app/browser. Port forwarding/static IP will be needed for this
The bigger the hard drive the better. On a 4 camera system you want at least a 4tb..... Ideally more . This will keep the frame rate and resolutions decent
IMO You'll need a months recording to be of any use etc
Also think of putting them on a ups for power outages
