Home CCTV setup
Waitey
  Alpina D3, AC Cobra
Looking for options on this.
I have no idea where to start.
Needs to have 3x cameras - With night vision setting.
Screen to monitor them
Central HDD to record it all.
Whats out there?
Marc.
Doesn't @Gaz_ do home security setups? Might be home entertainment - but someone definitely deals with this stuff on here...
JohnnyE
  ITB'd Clio
Have a search for Hikvision recorders and HD cameras good bit of kit.
Trainerbrow
  Mk1 Audi TT 3.2 V6
Our local pub recently had a cracking system fitted where the cameras track cars moving up and down the street
Andy_con
  clio 182
you could get away with a decent IP camera and record on any laptop/computer.
it depends if you want a dedicated recorder or not?
I use an old desktop that isn't connected to the web, so just records 24/7 365 days a year.
Waitey
  Alpina D3, AC Cobra
Ideally needs to be completely standalone. I can rig and old PC up for the recording.
Andy_con
  clio 182
I got my ipcamera off ebay, cracking bit of kit. it has never left me down, just sits there day after day recording onto a 1tb hard drive.
  182, SQ7, Trafic
Hi!
3x 2CD-2732 HIKVision domes with built in Micro SD cards and an iPad mini with app and done.
Marc.
It says you've tagged me?! Which would be correct!
I did, but I couldn't remember if it was you or not, I knew Gaz also did it so edited you out, in case I was wrong and dragged you into a random thread :)
Waitey
  Alpina D3, AC Cobra
Hi!
How much for all that, excluding the ipad (this needs a wall mounted screen of decent size?
How do they draw power?
OEM Battery Nonce
I bought a sannce kit off amazon for my house, got 4 cameras with infrared night vision, control box suitable for 8 cameras, all cables and a 1tb built in HD for about £170. Has an app to watch remotely and record what you see or can be watched on the TV through HDMI.
So far it's been as good as I'd expect. The email functions to email when motion is detected or a camera wire is cut can be a little temperamental but other than that it's spot on for the money
  182, SQ7, Trafic
Draw power using Power over Ethernet. So you just have one Ethernet cable going to it and it draws it from a POE network switch.
For all that your looking at about £800+VAT.
If you wanted a monitor you would need to connect it all to an NVR so looking at another £500+VAT.
These are proper quality though.
Standard CCTV Image
Vs. HIK Vision at 1080p 30FPS
Waitey
  Alpina D3, AC Cobra
Standard CCTV Image
Do you work nationally?
I'd have two commercial locations for you to do. One needing 2 cams and one needing 3 cams.
Can supply info for quote if needed.
  182, SQ7, Trafic
Send me a PM with some info and locations. We do a lot of commercial locations, offices, oil depots etc...
riz
  Jaguar XFR
Quick Noob query...
I have one CCTV camera at home.. It sends me motion alert images when I'm not there and saves videos to the onboard SD card. If i want it to record all the time to somewhere is it best to use an NVR or upload the videos to somewhere ?
Gaz_
  Extreme mode
Yeah go for hik vision or Dahua as they are pretty comparable in price vs quality. All systems we fit are IP, powered down the cat5 cable
One thing to note,
Dont have them too high up or all as you'll see is tops of heads,......
For intruder identification you need to ideally be filling over 50% of the image
Gaz_
  Extreme mode
Something like this
http://www.cctvsuppliersuk.co.uk/se...xel-ip-cctv-kit-4-channel-nvr-with-4-cameras/
Plus a monitor. Then think about hooking it into your network for remote viewing via app/browser. Port forwarding/static IP will be needed for this
The bigger the hard drive the better. On a 4 camera system you want at least a 4tb..... Ideally more . This will keep the frame rate and resolutions decent
IMO You'll need a months recording to be of any use etc
Also think of putting them on a ups for power outages
  Yellow 197
I would recommend against anything Wi-Fi based or recording to SD cards
Run cables to cameras and have it recording to a dedicated NVR like Hikvison or Dahua as mentioned above
I would also recommend against NAS drives too, complicates things and I have know hard drives have a high fail rate as the disks are constantly recording
  Yellow 197
Something like this
Most Hikvision and Dahua have built in DDNS so no need for a static IP, simply forward the ports and away you go
