can someone please take a picture of their twin horns when they are installed and with the connectors on? looks like someones done a bodge of mine at some point!
Im guessing the right hand horn as you're looking is meant to have something connected to the nearest 'stump' (which has the little prongs around) it to the camera?
just not sure how something will connect to it.
It depends if they are dual or single connection? Personally I would splice the original horn wire to the other mounting post as well without it I dont think it would get power?
Yes the RH horn does not appear to be connected to any wire atm. There is a spare wire there which suggests it connects to the rh horn but it doesn't look like it will connect to it - wondering if a connector etc has come off or something which is why i wanted to see what it's meant to look like.
It would look like the one on the LH horn, to test the theory get some scrap wire put one end on the positive of the battery and touch the other end on that post on the RH horn if it sounds... then you need to connect that wire to the horn some how weather you botch it or find a clip
