Whist removing the small bottom trim from my steering wheel, I pulled the horn push up a bit to make removal a bit easier, but when I reseated the centre section, my horn doesn't work.
If I pull the centre out a bit, the horn will work, but it obviously reseats and stops working....
I assume I've misaligned something, but how do I get into the horn/airbag centre section to rearrange it? Found how to remove the airbag module (2 clips behind steering wheel) but no threads on how to open it. Not keen to pull too hard on the cover because of the airbag so any advice or pointers to historic threads gratefully received.
