Horn stopped working - ph1 stalk in ph2
When I was fitting a new column I accidentally touched the metal prongs (red and black cable) onto the column with it plugged in and it sparked. I tired a couple of new fuses but nothing.. Is there anything else I can try or will I need a new stalk? Thanks in advance
  dan's cast offs.
Probably just the horn. Common to not use it, use it and it's fine and then next time nothing!!
Give it them a tap with a hammer and see if that sorts it.
