horrible noise from engine bay
Car  Clio 1.4 16v
hello, i have a 1.4 16v and just had cam belt done since it has been done ive got this noise coming from that kind of area sounds like some one is scratchin metal kind of or something catchin any help would be great thanks,
loz
was the noise there before the timing belt was done ?
could be the alternator , common on these , try running it without the auxillary belt on and see if the noise goes.
you may be able to see the alternator pulley cutting into the casing.
could it be the dephaser pully.... the noise doesnt start till the engine is warm and can only notice it on idle
i did service the car just before i had the timing belt done and used 5w 30 oil
any more help pleaseeeeeeee
thanks loz,
does not have a dephaser , pos water pump , but you need to remove the aux belt when the noise is there to see if it goes or not, then check all items for movement play etc , press clutch see if noise changes , etc get it narrowed down to the area , , and was noise there before belt changed ?
no the noise wasnt there before they changed it i had the water pump changed when the belt was done OMG quite annoyin that these noises happen all the time suppose thats cars for ya thanks for your help if you have any more info that would be great
take it back to them. i second the comment above, take the aux belt off as this will whittle it down alot. only thing i can think of is a loose bolt on the water pump has come out a bit and it catching as the pump goes round, and this could go bad very quickly. really need to get it back to them so they can take the cambelt cover off and see whats going on.
