Hot day starting
  Clio 172
Ok drove my car to work fine started fine in the morning from cold went to it after work when it had been sat in the sun all day and it started but only just it's done this before and only does it on hot days if it's been cold all day the car starts fine any ideas
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Any warning lights on and has it done it since? Crank sensor, fuel pressure, injectors are all possibles.
  Clio 172
No warning lights it's done it since iv owned it Wich is only 3 mounths would a diagnostic pick up any of the above ?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
They'd need to be tested electrically before you go off and start buying "miracle products"
Start with a proper diagnostic session and go from there.
Mick
  04 Monaco Blue 172
mine did this, it was sat in the sun all day and i had to blip the throttle to make it start
i ran the tank empty, put some redex in it and used 99 momentum fuel and i also cleaned the throttle body, fires on the first turn of the key now
