How do I go about performing an oil change
  Clio 172 Ph1
Hi I've had my car for a year and have done about 9,000 miles. I think it's about time I get it sorted. I know I need to find the sump plug to drain it but do I flush it out afterwards? And how do I go about the filter?
Coops Mk1
  Lots of Scrap...
do this on flat ground
pretty much all there is to it is warm engine slightly so oil flows out freely. remove sump plug over the oil catch pan/cut up old container and let the lot run out
as its coming out, remove the fuel rail guard to ease access and unscrew the oil filter from the front of the block. use a tool if needed as may be tight
clean up the mating face on the block if needed, get new filter and run a small amount of new engine oil on the rubber seal and screw into place. do up hand tight, do not overtighten it. leave fuel guard off for now.
refit sump plug with a new washer (if you like, or reuse old one).
remove oil cap from top of engine and slap about 4-5 litres in. wait for a minute for it to accumulate in the sump and check level with dipstick
top up to just under the top notch on the dipstick and refit oil cap.
car in neutral, turn on engine and let the oil run round for a while and check the new filter to ensure no leaks.
turn off, let settle and check level again
if happy refit the fuel guard and done
take old oil to the tip
  Westfield, 182, 200
Have you got a friend or relative who could show you?
It's quite easy, but first time around could difficult!
  Clio 172 Ph1
Nice I am going to get all the tools ready before I do it so it isn't a disaster lol are the oil filter strap grabber things any good or better with the pliers
Coops Mk1
  Lots of Scrap...
yeah they should do the job. I usually opt for the stress relief option of hammer a screwdriver through it and bash it undone....however its not strictly recommended as if the end of the filter breaks away completely first, your in a bit of a pickle I wouldn't like to get a novice into ;) lol!
Lol I guess that's a back up ;) haha
I use the rubber strap type tool myself, not had a go as it'll be my first oil change but it seems very strong, after the weekend I should be able to tell you my thoughts of it :)
Anyone know if you could do the oil filter through the wheel arch rather than take off the fuel guard? Also how would you raise the car up to get underneath it in the easiest way?
  330i. E30 Touring.
No chance through the wheel arch liner. Aux setup is in the way.
From the top only.
  172 Cup
From the top only.
Absolutely! Plus it's only two nuts to remove the fuel rail guard. As long as you have a deep socket (10mm I think....) or an extension bar, it'll be easy. And remember to remove the guard carefully if the nuts have been left loose inside.
