How do I remove door bullets off my ph2?
Car  Ph2 FF 172
Middo has kindly agreed to do these for me and now I just need to get them off asap and send them. Question is... How easy is it to do?
Open your door, on the back edge of the door level with the bumpstrip is a little plastic/rubber grommet. Pop this off and then inside use a screwdriver to push the clip holding the bumpstrip towards the outside of the car. Then push up slightly on the bump strip and then it should pretty much fall off. Then take the badges off the bumpstrips. Makes it easier and only took me about five minutes on friday night.
persevere and proceed with caution or break the clips, which means it will be a pig to get back on.
middo did myne
