How do i run all this in my car???
Car  145db Euro'd clio
i got two JBL GTO door speakers, two standrad door speakers, two sony 150watt speakers, two sony tweeters, two JBL GTO 6x9's and Infinity Kappa sub. any suggestions on how to run all this? one amp, loads of channels (if so, any one selling one?) or two/three amps? :D
1) Remote to battery.
2) Ground to headunit.
3) Phono into headlights.
Done :)
What do you mean by run it in your car? :S
Wire it uP?!?
like whats the best way. one 6 channel amp or multiple amps. if i have multiple amps. how do i wire them together? because my head unit only have the two phono ports.
If you've got 6x9s that's enough for rear fill you won't need to standard back speakers although many will go against the 6x9s in favour of components. Also the magnets from the 6x9s if mounted on the parcel shelf can, so I've heard, slowly deteriorate the sub so I'd recommend boxing them.
On the other hand, I'd get a seperate amp for the sub and the 6x9s. Make sure you get the right amp for the sub so you can achieve maximum power output from it.
Replace the front door speakers with the GTO's also and put the tweeters on the dash.
And get a new headunit!
I'm sure someone will probably disagree or add to that but it's worth a shot :)
With car audio 'Less' is usually 'More'....
Obviously its your car, your set up, your choice....
Personally I would start off easy & add to your system over time, rather than simply cram everything in & struggle to get it sounding right....
You seem to be paying little or no attention to the power supply or installation....These two things can, & will, greatly affect your final results....
No mention of musical preference, no mention of the desired effect your after & no mention of budget, just how can you expect anyone to offer worthwhile advice ????
Before you do anything you should consider exactly what you want your audio set up to do, are you chasing quality?? Are you chasing output with good levels of quality?? Or maybe your just after some low end grunt??
Try to visit a few audio outlets & demo different brands, try to get out & listen to a few different setups in different cars, once you've heard a few you will find it easier to decide what will suit you....
Remember, high output systems require power to run, no point buying/fitting large systems if your not prepared to sort your power supply.....
Anyways, have a think, then maybe start a new thread including a little more relevant info about what your after, (good car systems are planned, they don't simply happen)....
