I've got a MK2 PH2 Need to open it up to access the battery....
Ruffneck Black PH2 172 FF Oct 22, 2006 #1 I've got a MK2 PH2 Need to open it up to access the battery....
L lemonnobby ClioSport Club Member Oct 22, 2006 #2 on the back there is a arrow push top bit forward and bottom bit back
L lemonnobby ClioSport Club Member Oct 22, 2006 #4 yea it will be tough use a spoon handle where the key ring goes it.
Has RS 182 - Black Gold Oct 22, 2006 #5 Make sure you take the keyring out first Then as said slide it in the arrow direction while pulling on the underside in opposite way. Takes some doing if its not been done for a while or if the key is quite new.
