How do you remove power steering resovior
Car  A3 2.0TFSI QUATTRO
I need to remove my power steering bottle/resevoir is it just the clips on the side closest to suspension turret or is there more to it ?
Any info to how i get it off will be appreciated
daz
On my cup it's held on with a tab that goes against the turret wall and the pipes were clipped\supported at the bottom to the ecu bracket.
GS in the tab to move the tab away from the turret, slide up and un clip the hoses from ecu bracket and it'll be free for you to do whatever with
yep pretty much as toast says; there is a tab type clip at the top oin the turret, push this in and the slid the bottle up the turret. It will probably be very stiff but it will slide out eventually.
