how easy is it to fit a head unit
BIFCAIDS
Car  340i M-Sport & 182
Hi ive sold my pug106 and took sound system out of it n im going to put it in the clio eventually how much of a task is it to fit the head unit!
Mike
5 min job at most.
biro or small screwdriver to remove the oem headunit, and assuming your replacement ha iso plugs for power & speakers they push directly in.
possibly worth removing the panel below the air con display if your tight on room and connectors are int he way as u can reach up and direct the wiring.
Thanks Guys n gals ill be having words soon then ill let you know S666MAH :cool:
