to fully change the whole system then bleed it
FiDoDiDo RB 182 Aug 20, 2007 #2 That I remember seeing that you need 1L and you might want a spare one as well but one should be fine.
FiDoDiDo RB 182 Aug 20, 2007 #4 ummm....sounds like I'm getting confused with something else then lol
A Ali V6, Trackhawk, GTS Aug 20, 2007 #6 ben_p said: its £65 per ltr!" LOL Click to expand... Its about 20 a litre you pleb! See castrol dot 4.1. You need 1.2l with 4 pots, not sure if you went down this route, the 4 pots require a little more.
Josh@Renparts www.renparts.co.uk Aug 20, 2007 #8 when i saw the title i thought you were planning an attack on lustys car...
Djw John Scotland - South ClioSport Area Rep Not a clio :( Aug 20, 2007 #9 Na youd be better just using cheap stuff for that
