How much extra bhp?
Car  Renaultsport clio 172 cup
How much extra would i get with a 182 manifold,de-cat,s/s k-tec stealth,itg panel filter and a rs-tuner on my 172 cup?
10-15bhp depending on how well the engine has been looked after/serviced, wouldnt bother with the 182 manifold for the money + agro fitting, de-cat, matched inlets & good exhaust will be the most noticable gains
James
James
Thanks for a sensible reply getting the manifold cheap so should be worth it whats the spec on on your engine?.
* Acoustic valve removed & up-rated CAF's installed
* Itg pannel filter
* Mathced Inlets, from Angel works
* PTFE Gaskets
* Group N re-map
* Gray's 2.5" bore de-cat
* Powerflow 2.5" bore full stainless sytem
Made 184.5bhp @ Fly... 153bhp @ wheels
I would say with your spec above you may touch 180bhp, does depend on what rolling road you use as some are just crowd pleasers.. with the inlets done you should be on 180+ but inlets are more of a torque improver than peak power, very happy with Ben @ Angelworks, done a great job on mine & very quick turn around
i just had mine on the rollers 2day
193.5bhp @ flywheel
156.3lbft of torque
all i have is a full milltek with decat and pipercross viper with CAF.
have no idea wot it was running standard as i got the exhaust and pipercross before getting it on the rollers
was feeling very torquey on the drive up 2 dashfixer aswell
cams and group n ecu map on there way next week
The only way to find out what you will gain is by doing a Rolling road fitting the mods then going back to the SAME rolling road and get the same operator and get a second run, it still wont be 100% but will be the best way.
Also use the AT THE WHEEL figure not the FLY figure,
Pepole will quote numbers on here but they are useless, because of the variables. for example at RStuning standard PH1 172 make 160BHP (at fly) yet at motorscope they make 175idh( at fly)
But if you can pick up a 182 manifold cheap it may be a good buy, but some say its not worth it.
can't remember off the top of my head but think mine was around the 145-149bhp @ wheels. printout is still in the car
Wheel figure can also differ, single to double rollers... how hard its strapped down, tire pressures etc.
so an accurate loss figure for that particular car is also important.
* Itg pannel filter
* PTFE Gaskets
* Group N re-map
193.5bhp @ flywheel
156.3lbft of torque
Point proven u seem to have less power at the wheels than james claims yet you claim more at the Fly :rolleyes:
also, binding brakes, wheel bearings, poorly gearbox... all add losses to the power output and if not measured with loss readings are uncomparable
matched inlets are best best bang for buck on a 1*2 IMO. But the 182 manifold has advantages also. I'm pleased with mine, but I think it could well be the decat that's given most of the gains.
