I can feel quite a noticeable amount of movement through my gear stick when I lift off, or let the clutch out quickly on my (new to me) 172.
I've had my local garage (not a specialist) check the gearbox mounts and they say that they are fine and I should expect movement as normal on this car because of the big ish engine and the mounts are soft.
Are they correct? Is movement normal with the standard mounts? Can it be rectified with aftermarket mount kits?
