Have you checked to make sure its replaceable on your driveshaft? And that it is the right size and has the correct number of teeth etc?
According to renault dialogys (or whatever its called) you cant get rings for anything other than the RS models. Whcih suggests that the ring isnt removeable or even available for the non-RS models.
My haynes manual says that in some cases the abs ring is integral to the driveshaft, pretty sure its the case with the non RS models to be honest. If not, there will be a part number on the system for a 1.2 ABS ring.
