pop the plastic off the back of the tailgate, The wiper has to be pulled off the mechanism and is a right b**ch to get off, I found the easiest way is to hax saw it off and then just undo the bolt from the back. Some people get them off with pullers but i never had any luck and didn't want to smash my glass.
Have to flip up the cover. Remove small nut. Then remove arm from spline. But will most likely be stuck on solid. There is a trick to get it off using two spanners.
Failing that grind it off. Then remove large nut sitting behind that.
From inside car, one Torx screw on boot interior plastic. Then plastic trim just pulls off. Held on by plastic clips.
Then three/four bolts holding wiper motor on.
Is a guide in the guide section, but have to be a full member to view.
