How to get content to TV?
Steve
Car  LMC10, Puma E
New extension has TV aerial socket on wall, wife now wants different seating layout to one we discussed (FFS now she tells me)
So how do I get signal to TV without trailing cables (not allowed)
Have a selection of power points on different walls in extension.
Have BT infinity unlimited & youview box but these are in the lounge.
Should I be using powerline adapters & an additional youview box?
Have a smart Panny VT TV & can buy another smart tv if needed.
Is there a simpler idea?
Relocate the TV aerial? I'm asuming it comes in from the outside, if so just put it through the wall in the correct location?
Cheers,
Point on inside wall of ext she wants on outside of original wall.
Flooring/skirting already fixed painted & sealed!
dang.
I'd suggest trunking....but it looks hideous even in its native office environment
Run a fresh coax cable from the aerial to the exterior wall. put a hole in the wall, feed the cable through it. Job done.
This is assuming you have an external aerial of course, and not one hidden in the roof/loft
Or tell the wife to stop f**king about and she's either got to have a cable running round the room or the TV in the original place!
Tell the wife to be grateful she's got an extension and to STFU.
Job done.
trunking would be you only real way of keeping it out of sight, if you can not put it behind skirting ect, or get a white cable and some cable tacks, and run it along the top of the skirting ?
