It should be possible, just easy when walking away from your car and just hear your car being locked instead of turning round to look at your indicators...
http://www.youtube.com/watch?v=8snwh4S30vg
For example something like this, just at the beginning of the video when he locks the car.
For extra awesome point, when too far away for it to lock, hold the fob to your chin and press it again.
Locked.
ANTENA HEAD!!!
LMFAO, does that actually work COOKSON?
Cheeky question: fancy doing a guide?All you need to do is wire in a relay to one of the indicators so that if the indicator flashes when the ignition is off it triggers a beeper.
Would effect hazzards too, but you could get round that if it bothered you.
Not really tbh as its probably only ever going to interest you so not really worth doing a guide for.
Just use the switched side of the relay to connect an indicator live to the beeper. Put the other side of the beeper to earth. Then put the normally closed side of the relay to the ignition and the common to earth.
Then it will beep if the indicators flash and the ignition is off. Ie only for the alarm arming and hazards.
Doesn't that mean something's still open? I always unlock it again and then re-lock, the beep never happens a second time
