How to remove a few things without damage!
Car  BG 182 & 225 T
How do you remove the bullets, do they just pull off/slide off or do you pull the whole bump strip off first?
also the Renault badge from the front and back, pull off or how is it done?
Use a flat head screwdriver wrapped in cloth and they just pop out :) very careful not to snap any of the clips though
Not sure how the back comes off as I haven't done that yet
Its easy to remove the whole side trim, I always use plastic trim tools though, just need to get the little securing lug to come out the door then they slide backwards. You can then just push the bullet clips from the back, no need to worry about damaging them!
Rear Diamond requires the whole lock piece to be removed, so interior panel off, then theres 3 8mm nuts holding it on, undo those and it'll come off, If I remember correctly, the badge is secured by melted lugs. Front, comes out with the small black piece behind it, has two T20 torx screws holding it to the bumper, that also has melted lugs holding the diamond to the black piece.
Cheers for that managed to get the bullets off anyway!
Do you have to take the bumper off to get the front badge off, seems impossible to get to the screws!
