How to remove dash?
Not that I know of.
Remove 3 torx screws near windscreen vent, 2 to the right of steering wheel (behind trim), 3 above glove box (behind trim), 2 either side of dash when doors open, 2 behind the steering wheel colum ( pull down lower steering wheel cover then remove top). Remove A pillars (be careful of alarm sensor wires).
Sit in the middle of dash and pull away both sides at the same time.
Good Luck.
Not that I know of.
Good Luck.
Thanks very much, that will come in handy!
Does the steering wheel have to come off? I'd rather it didn't!
no the steering stays on make sure you take a photo of where the dials are incase you move them
its quite easy,im sure the was a guide.s**t that was the dash top i dont know how hard the whole thing is.
