How to remove door card MK3 Clio
Can anybody advise me how to remove the door card from a MK3 Clio?
The door won't open from the inside and with the MOT looming I really have to get this looked at.
Thanks in advance.
I'm assuming they are roughly the same as a mk2 Clio (don't count on everything I saythough) but with mine I do:
1. Remove torx screw from behind the cap on the inside handle (located centre)
2. Remove torx screw from door grab handle on door card
3. Remove cover cap over the speaker ( a little help from a flat head screw driver and it clips away)
4. Remove 4 Phillips screws from speaker and remove and disconnect wires also the window sitch wires )
5. Remove 3-4 torx screws from bottom of door card (underneath out of sight)
6. Pull from the bottom up using a bit of force but not to much to break the clips and from there it should just unclip mine had like a black silicone glue on that just pulled off with some force and to take off loose card lift up and un clip from thR window section done
Only use as a rough guide as I've never actually seen the Interior of the mk3 Clio
Nick
