RB 182 Cup
as above, i had a quick look.. no idea at all..
anybody know?
182 cup..
anybody know?
182 cup..
Obtain 4 new pop rivets for the plastic filler cap housing from Renault (and make sure you have a head large enough on your rivet gun to put the new ones in!!!)![]()
Drill out the old ones, remove the 2 torx screws and if possible, remove outer flap & hinge (I believe they are held by 2 bolts that have to be undone from inside the wing)
Remove loose rust & paint & treat with rust stopper (does anyone have recommendations on a make of rust stopper???)![]()
Mask off area & spray with primer (or primer filler) and once dry, sand area until smooth.
Spray with colour and allow to dry (I think the original paintwork in the area wasn't lacquered - so I shouldn't need to do this.)
Reassemble the components - hopefully job done!?
i used a pair of grips to stop the bolts from spinning then undid the 2 ten mills under the wheel arch
The bolts are captive in the platic so you can't grab the bolts without ruining the plastic. You'll see them as you open the flap.
