Pull the front one off, simple as that!
Rear - Take plastic trim off from inside of boot, 1 torz screw and a few clips. Once the screw is undone give it a pull and it should come off easily. Then you'll see 3 bolts holding the handle on. Undo the 3 nuts then take the handle off.
Then remove badge.. i think its glued on from the 4 pins at the back. When i took mine off i just scraped the glue off with a screwdriver, and glued it back in when finished
