How to remove wings, do headlights have to come completely out or just pulled forward
  clio 1.2
Re: How to remove wings, do headlights have to come completely out or just pulled for
i sure am fittin full kit next week for spray, will check it out now cheers pal
  Cup In bits
Skirts need to come off for wings to be removed properly and headlight out.
Again with the sideskirts you can just undo the front and pull them away from the wing to come off.
If you're making a replica though, sideskirts won't be an issue.
  Cup In bits
Was thinking he had a 1*2.
Anyway for a 1-*2 there's a bolt or a nut behind the skirt for the wing hence why I'm saying they need removed, right...? and the front rivets on the skirts will need drilled out to even pry the skirt out if that's the way you do it, I personally would do it right so the skirt doesn't get deformed like a lot of the cars you see about.
