How to remove?
Lol they dont give you that option you just get it as standard...you'll find a few more as you go along
Kiza
Undo the 4 torx at the bottom and then the one for the door release and then the one in the door handle by the window switches. Then its a case of prizing it from the door.
There are clips by the rear edge, one in the middle and two at the front of the door you just have to use a bit of brute force to get them off. :cool:
you also need to remove the plastic that goes up the edge of the window, unclip this from the top down and lift up. And the small corner bit of plastic down by the mirror, unclips straight off.
as for the door panel, work your way up from the bottom pulling and you will hear/feel it pop of the panel clip, then lift up off the of the window rail. Oh and if its the first time they have come off your gonna need a bit of force to get that glue to break. Bit of a b**ch to locate back on but nothing major.
