How to Secure a Sub
Car  182 BG
Heyy guys,
Really as the title says, I've picked up a used sub + amp from a friend thats in need of a little TLC - BARGIN! I'm just thinking though, whats the best way to anchor it into the boot? I want to be able to easily (ish) remove it, so I can use my full boot space if needed... Wiring isnt a problem for that, already figured it out... Oh, I have a Clio MK1 if it helps...
MCTW
Mine came with a few velcro strips that you stick onto the bottom. hasnt ever moved and then when you want just pull it out lol simple ;)
I've seen a few pages that recommend heavy duty velcro too... Out of interest, did you stick the velcro to the carpet? Or to the metal underneath and cut the carpet out...
Yeah velcro is a brilliant idea :slap:
Get it bolted down! Or just don't ever brake suddenly or drive in front of anyone you suspect might rear-end your car and force the sub towards the windscreen.
Seriously though, heavy duty or not. Think of the weight of even a small sub + the force of an accident :dead:
