Being stiff isnt an indicator os a shot box. Thats an indicator of a tight selector, wrongly adjusted selector, or similar. Crunching of gears on selection indicates worn syncros, jumping out of gear on hard acceleration, whining noises (bearings) all symptoms of knackered boxes.
the gearbox is gone if its disapeared, to diagnose fully sit in the car and swing your left hand around infornt of the handbrake, is a metal stick fouls your swinging then its not gone anywhere
Ive been worrying about the box in mine, but I think its just me not used to the heavy clutch and the fact that when I disengage the clutch without enough rpm (which is pretty much how I drove my 1.4) im liable to come close to stalling.
Ive found the best way is hover the revs at 3k and rapidly disengage the clutch to get a nice smooth & rapid takeoff.
On more serious note, while the car is rolling forward in gear, push the accelerator in hard. if the revs shoot up but there is a noticable delay in acceleration, then your box is most likely shot.
Ask Nick R. Apparently if you open up the bonnet and the gearbox isnt where its supposed to be, then its probably stuffed. Im a bit worried about mine at the moment, i double de-clutch, but im still getting nasty changes.
Ive already had my gear box replaced under warranty on my mk.1 172 and the monkeys at the renault garage didnt fit the new one properly and it leaked gearbox oil all over my drive - this appears to have inspired premature wear on the new box - great! the new box is doing the same as the old one: crunching in 2nd, 3rd and 4th. Nasty.....
